OrangeBlue
May 04, 2020Aspirant
Orbi Issues After Firmware Update
I updated the firmware on my RBR40 and RBS40 to latest version and they have become extremely unstable. The Orbi App periodically says it is not compatible with my router, which seems very odd. The RB...
OrangeBlue
The satellite is connected via Ethernet. System was incredibly stable until I updated it.
May 04, 2020Guru - Experienced User
Is the RBS connected directly to the RBR or connected to a switch? If a switch is in the mix, what is the mfr and model# of this switch?
Be sure Daisy Chain is disabled if you have the RBS connected via ethernet.
- OrangeBlueMay 04, 2020AspirantNo switch in between.
I turned off daisy chain, but no difference.- FURRYe38May 05, 2020Guru - Experienced User
Please try a factory reset and setup from scratch with the RBR and RBS.
