Ridleye's avatar
Ridleye
Orbi jittery with ring central
Ring central voice calls are impossible on my orbi router. 1gb connection, and the calls either jitter or drop.
  • What Firmware is currently loaded?
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    What WPA security modes are you using?
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • Ridleye's avatar
      Ridleye
      2.3.1.48
      Router Mode
      3400
      1 Satellite ,~50 ft
      I'll try that
      A dozen or so strong signals
      WPA2-PSK [AES]
      All enabled
      I'll try
      THANK YOU
  • What is the Mfr and model# of the ISP modem the NG router is connected too?
