davidartiss
Oct 31, 2021Star
Orbi jumping between connections
Hi, I have the RBK753, so have 3 routers in total. My primary router is on the middle floor with each of the others on the floor and below and above, respectively. They're all on different sides ...
davidartiss
Oct 31, 2021Star
Thanks for the reply.
The location the satellites are in are the best - particularly the location of the lower one. If move it any further either direction, some thick internals walls cause issues.
Oct 31, 2021Guru - Experienced User
Best for the devices on that floor or the best for the connection between router/satellites?
Everything is dependant on a good wireless backhaul connection. It doesn't do you any good to have a great connection from satellite to devices if the satellites connection has a poor connection.
It'd be like having a race car that can only have a straw to feed the motor fuel.
- davidartissOct 31, 2021Star
So what would be your recommendation here? The lights indicate blue, and eveything in the app suggest strong signals where it is - throughput it great, with no problems. It's just that jumping between satellite and router that's causing a problem.
- plemansOct 31, 2021Guru - Experienced User
what size is the home?
How far apart are the satellites from the router?
What is the interior walls and floors made from?
That series of orbi doesn't let you enable/disable dasiy chaining. Its all managed automatically. So if the device from floor 1 is connecting to the satellite from floor 3, it makes me think somethings causing that. Either to close or somethings blocking the signal.
That's why I said try moving the sateliltes around
Understood.
I don't have exact measurements, but it's 3 stories with quite thick, Edwardian walls internally. On the ground floor, in a middle room, is a satellite. On the floor above, near the front of the house is the primary router, where the broadband comes in. On the top floor is the other satellite, in a similar location to the one on the ground (just directly above).
Between the bottom and middle floor satellite/router is a couple of walls, but where the ground satellite is, there are open doors between, so there's really only a floor between them. If I move that satellite any nearer, it moves away from a camera I have mounted outside the back and has connetion issues. The room isn't set up for me to move it further away, unless I move it in the back room (the kitchen). However, due to the extra wall, the satellite then complains about a weak connection. So, I've tried already... but will keep at it. You've actually answered my question, though, in that I can't fix the connection. Thank you.
