Salmutairi
Jul 01, 2019Aspirant
Orbi keeps desconecting
I just set up orbi 53 and updated it but i notice it keeps disconnecting every 30 minutes it is not isp provider issue it is the mesh system issue. The router connected to netgear m1. M1 wifi disabled...
Jul 12, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Salmutairi wrote:
I just set up orbi 53 and updated it but i notice it keeps disconnecting every 30 minutes it is not isp provider issue it is the mesh system issue. The router connected to netgear m1. M1 wifi disabled. The router and its 2 setlites are green they are close to each other.
