Salmutairi
Jul 01, 2019Aspirant
Orbi keeps desconecting
I just set up orbi 53 and updated it but i notice it keeps disconnecting every 30 minutes it is not isp provider issue it is the mesh system issue. The router connected to netgear m1. M1 wifi disabled...
michaelkenward
Jul 13, 2019Guru - Experienced User
That is probably the MR1100 Mobile Router. Disabling wifi does not disable the router. But disabling the router does disable the wifi.
There is support for the MR1100, including a manual, somewhere at the end of this link:
>>> MR1100 | Product | Support | NETGEAR <<<
Check the section Enable IP Pass-Through Mode or consider putting the Orbi into wireless access point (AP) mode.
