Salmutairi
Jul 01, 2019Aspirant
Orbi keeps desconecting
I just set up orbi 53 and updated it but i notice it keeps disconnecting every 30 minutes it is not isp provider issue it is the mesh system issue. The router connected to netgear m1. M1 wifi disabled...
Jul 13, 2019Guru - Experienced User
Any progress on this?
Salmutairi wrote:
I just set up orbi 53 and updated it but i notice it keeps disconnecting every 30 minutes it is not isp provider issue it is the mesh system issue. The router connected to netgear m1. M1 wifi disabled. The router and its 2 setlites are green they are close to each other.
