dainamuc
Jun 01, 2019Tutor
Orbi keeps disconnecting
My Orbi keeps disconnecting and purple light appears. I try to reconnect it but it takes at least 4 attemps before it connects again. Or it will sometimes connect back by itself. The issue happens ma...
Jun 01, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
Which unit displays the purple LED on top? The RBR or RBS?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling WMM, Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
dainamuc wrote:My Orbi keeps disconnecting and purple light appears. I try to reconnect it but it takes at least 4 attemps before it connects again. Or it will sometimes connect back by itself. The issue happens many times a day, internet is completely unreliable. Any ideas on what could be done to fix it?
