dainamuc
Jun 01, 2019Tutor
Orbi keeps disconnecting
My Orbi keeps disconnecting and purple light appears. I try to reconnect it but it takes at least 4 attemps before it connects again. Or it will sometimes connect back by itself. The issue happens ma...
honyin
Jun 02, 2019Aspirant
Hi,
I've been suffering this same issue.
It seems to have become a regular occurrence since upgrading the firmware to V2.3.1.60.
I have since manually downgraded the firmware to the previous V2.2.1.212.
Hopefully that will help.
I'll keep you posted.
Steff
ekhalil
Jun 02, 2019Master
This is an issue that I also saw in the latest software updates (since 2.3.1.28).
I fixed my issue by reducing the DHCP lease time as follows:
* From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
* Enter admin as user name and your router’s management password
* Tick "Enable Telnet" option
* Use Telnet from a computer attached to Orbi to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above
* Enter the following commands:
* root@RBR50:/# config get wan_lease —> Should give you 86400
* root@RBR50:/# config set wan_lease=750
* root@RBR50:/# config commit
- Reynold65Sep 15, 2019Initiate
ekhalil wrote:This is an issue that I also saw in the latest software updates (since 2.3.1.28).
* root@RBR50:/# config commitI want to thank you for this solution, because after setting the wan_lease=750, I have not had anymore problems with the random disconnects every 20 minutes or so.
