dainamuc
Jun 01, 2019Tutor
Orbi keeps disconnecting
My Orbi keeps disconnecting and purple light appears. I try to reconnect it but it takes at least 4 attemps before it connects again. Or it will sometimes connect back by itself. The issue happens ma...
Blanca_O
Jun 04, 2019NETGEAR Employee Retired
We just want to check if the steps provided by ekhalil and FURRYe38 were helpful.
Blanca
Community Team
honyin
Jun 05, 2019Aspirant
Hi,
Thanks for following up.
I rolled back to the previous software and that seems to have cured it.
I've had no dropouts since Sunday.
Steff
