dainamuc
Jun 01, 2019Tutor
Orbi keeps disconnecting
My Orbi keeps disconnecting and purple light appears. I try to reconnect it but it takes at least 4 attemps before it connects again. Or it will sometimes connect back by itself. The issue happens ma...
valain
Jun 05, 2019Aspirant
Exactly the same issue here. See thread on Reddit https://www.reddit.com/r/orbi/comments/bwziim/orbi_issues_loss_of_wifi_and_cable_connectivity/
- FURRYe38Jun 05, 2019Guru - Experienced User
After loading v60, try a full factory reset and setup from scratch.
Does wired and wireless have no access to internet?
I have not experienced this issue with v60 loaded...
valain wrote:Exactly the same issue here. See thread on Reddit https://www.reddit.com/r/orbi/comments/bwziim/orbi_issues_loss_of_wifi_and_cable_connectivity/
- FURRYe38Sep 15, 2019Guru - Experienced User
Any progress on this?
