dainamuc
Jun 01, 2019Tutor
Orbi keeps disconnecting
My Orbi keeps disconnecting and purple light appears. I try to reconnect it but it takes at least 4 attemps before it connects again. Or it will sometimes connect back by itself. The issue happens ma...
valain
Jun 05, 2019Aspirant
Exactly the same issue here. See thread on Reddit https://www.reddit.com/r/orbi/comments/bwziim/orbi_issues_loss_of_wifi_and_cable_connectivity/
Sep 15, 2019Guru - Experienced User
Any progress on this?
valain wrote:Exactly the same issue here. See thread on Reddit https://www.reddit.com/r/orbi/comments/bwziim/orbi_issues_loss_of_wifi_and_cable_connectivity/
