Falfam5406
Aug 12, 2018Aspirant
Orbi keeps dropping the DNS!
My house got stuck by lightening a few weeks ago and fried our TV, modem, receiver, projector, etc - the orbi + satellite were spared amazingly. We bought the same NETGEAR modem but upgraded from CM6...
Ranholl
Check the channels for 2.4 and the 5 ghz I have found the Orbi works great but does not play well with others
had the same problem and run a WiFi scan and found crossing channels separate by at least 3 channels and try again
- Falfam5406Aug 12, 2018AspirantWhat do you use to scan for WiFi channels?
- RanhollAug 12, 2018AspirantI use a Apple WiFi app to scan for signals and the chains
You should find a WiFi scanner in the App Store
