s281er238
Feb 02, 2019Aspirant
orbi keeps getting on 2.4 and not 5 ghz
my orbi keeps jumoing to 2.4 and when in range dosent hand off properly to 5 ghz on my devices and i have 2 satelites and ne router whcih covers the whole house open floor plan np walls . why cant th...
schumaku
Feb 02, 2019Guru - Experienced User
It's in the first priority the wireless client deciding on the band to use, not the access point (e.g. Orbi) deciding on the band to be used by a client. If the signal is not good enough, the 5 GHz channel active on-air is not available on the client, or the connection does fail repeatedly, clients fall back to 2.4 GHz.
Hacks to split off the 2.4 GHz and 5 GHz radios are published in the community already.
