s281er238
Feb 02, 2019Aspirant
orbi keeps getting on 2.4 and not 5 ghz
my orbi keeps jumoing to 2.4 and when in range dosent hand off properly to 5 ghz on my devices and i have 2 satelites and ne router whcih covers the whole house open floor plan np walls . why cant th...
Feb 02, 2019Guru - Experienced User
What WPA security modes are you using?
Try enableding Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
s281er238 wrote:
my orbi keeps jumoing to 2.4 and when in range dosent hand off properly to 5 ghz on my devices and i have 2 satelites and ne router whcih covers the whole house open floor plan np walls . why cant thy just enable duable band where you have separate ssid for 2.4 and one for 5 is it gone kill them i hate this automatic come on guy its great setup but it fails without separate network please have that option enabled soon for advbanced users . does anyone know how to crack that or open that option up that where this device fails keeps jumping to 2.4 and stays on 2.4
