guilloryjc
Jun 03, 2020Aspirant
Orbi keeps rebooting several times a day even with new firmware V2.5.1.16
House: 3200 sq. Comcast: Internet Router and satellite are around 30ft., no walls blocking them Modem Arris SB8200 Firmware updated automatically through admin page (V2.5.1.16) I'm having t...
pshah
Jun 24, 2020Aspirant
I have been having the exact same issue with this firmware version. Orbi reboots 6-7 times a day. I have done factory reset and still nothing. Very frustrating.
Jun 24, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
