guilloryjc
Jun 02, 2020Aspirant
Orbi keeps rebooting several times a day even with new firmware V2.5.1.16
House: 3200 sq. Comcast: Internet Router and satellite are around 30ft., no walls blocking them Modem Arris SB8200 Firmware updated automatically through admin page (V2.5.1.16) I'm having t...
fmalloy
Jun 24, 2020Luminary
If your unit is rebooting itself spontaneously, forget all the contortions and resetting and questioning your modem and house size. It's defective. It's what happened to me. There is a flaky component, one possibility is bad RAM, where memory data gets corrupted.
Once I got a replacement router, it's been solid...so far.
Jun 24, 2020Guru - Experienced User
Lets see if this is a configuration or other wise first before claiming it's a HW issue. Trouble shooting needs to be done first. Not every unit is faulty.
- pshahJul 02, 2020AspirantI have had the router for 3 years so definitely not a faulty hardware. I try tweaking the settings one at a time and so far changing 2.4ghz channel to 1 after factory reset helped. Over 24 hours with no reboot. Channels 6 & 11 did not help.
Thanks for the suggestions.- FURRYe38Jul 02, 2020Guru - Experienced User
Glad the suggestions helped.
Please mark your thread and solved so others will know.
Enjoy. :smileywink:
Thanks for the suggestions.- pshahJul 02, 2020AspirantI am not the original creator of the thread so I cannot close it.
