guilloryjc
Jun 03, 2020Aspirant
Orbi keeps rebooting several times a day even with new firmware V2.5.1.16
House: 3200 sq. Comcast: Internet Router and satellite are around 30ft., no walls blocking them Modem Arris SB8200 Firmware updated automatically through admin page (V2.5.1.16) I'm having t...
pshah
Jul 07, 2020Aspirant
I am back to square one. It was good for few days but started rebooting again. Rebooted 5-6 times today.
Jul 07, 2020Guru - Experienced User
You might try the new FW update on your ssystem. Manually download the FW files and install them. RBS first then RBR lastly. I would factory reset the system after the update then setup from scratch and see how it goes.
If this still fails, then I would contact NG support and open a support ticket.
- pshahAug 31, 2020Aspirant
I tried everything and finally downgraded router and satellite to 2.5.1.8. Its been stable for a while now.
- FURRYe38Aug 31, 2020Guru - Experienced User
Ok, next time an update is seen, update the RBS first, then the RBR lastly.
- MstrbigAug 31, 2020Master
Usually when any router reboots itself several times a day, it can be getting overheated or defective, or a bad or going bad power supply. I had an Orbi power supply cause an RBR50 router go on and off every 10 seconds, just like a timer was controlling the power. If possible try a different equivalent power supply and see if the problem goes away.
