bigmoviebuff
Jan 10, 2020Tutor
orbi keeps rebooting
my orbi reboots a few times a day. support suggested 1. updating to the latest firmware 2. disabling my verizon wifi with these instructions - https://kb.netgear.com/31100/How-do-I-set-up-my-Orb...
bigmoviebuff
Jan 10, 2020Tutor
i have the RBK50 with one satellite.
- Blanca_OJan 15, 2020NETGEAR Employee Retired
Hi bigmoviebuff
Welcome to NETGEAR Community!
To clarify, when you say Orbi reboots, do you mean the device turns off and on?
Blanca
Community Team- bigmoviebuffJan 15, 2020Tutor
the router flashes white for about a minute.
Also the logs in the admin section clears.
- FURRYe38Jan 15, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too?What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a factory reset and setup from scratch been performed since last update?
Is there a buit in router and wifi with the ISP modem? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
