bigmoviebuff
Jan 10, 2020Tutor
orbi keeps rebooting
my orbi reboots a few times a day. support suggested 1. updating to the latest firmware 2. disabling my verizon wifi with these instructions - https://kb.netgear.com/31100/How-do-I-set-up-my-Orb...
Blanca_O
Jan 15, 2020NETGEAR Employee Retired
Hi bigmoviebuff
Welcome to NETGEAR Community!
To clarify, when you say Orbi reboots, do you mean the device turns off and on?
Blanca
Community Team
bigmoviebuff
Jan 15, 2020Tutor
the router flashes white for about a minute.
Also the logs in the admin section clears.
- FURRYe38Jan 15, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too?What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a factory reset and setup from scratch been performed since last update?
Is there a buit in router and wifi with the ISP modem? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- bigmoviebuffJan 16, 2020Tutor
I updated to the latest one - 2.5.1.8 it seems to help. less reboots now but it still happens every few hours.
What is the Mfr and model# of the ISP modem the NG router is connected too?actiontec MI424WR Rev 1
i used the default - auto. Also switched it to a manual channel and neither makes a difference
Any Wifi Neighbors near by? If so, how many?yes many. I live in nyc in a large apartment complex. maybe around 10
yes
i already tried switching to AP mode and disabling the wireless on my fios modem
(this was mentioned in my first post)
is it hardware related? Is it possible i have a defective orbi router?
- FURRYe38Jan 16, 2020Guru - Experienced User
Possible the system is faulty, if it continues to exhibit this problem after a reset.
