| Cascaded Router Enable: | On Off | |
| Cascaded Router Address: | ||
| Network Address: | ||
Subnet Mask:
Is this the same as IP Pass-THrough?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? If there is a built in router here, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
The router/wifi from Frontier is an Arris NVG443B ....
I will try to turn off the WIFI on that device .... but this issue just started happeing, We had no problems prior to the firmware update whcih I did yesterday.
Try a full power OFF of the ISP Modem, RBR and RBS for 1 minute then back ON as well.
I did the power cycle and also tried AP mode .... neither worked.
Can you provide some more detials behind how to do this:
I found a setting named "Cascade Router"
It has these settings:
Cascaded Router
Subnet Mask:
