| Cascaded Router Enable: | On Off | |
| Cascaded Router Address: | ||
| Network Address: | ||
Subnet Mask:
Is this the same as IP Pass-THrough?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? If there is a built in router here, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
The router/wifi from Frontier is an Arris NVG443B ....
I will try to turn off the WIFI on that device .... but this issue just started happeing, We had no problems prior to the firmware update whcih I did yesterday.
Try a full power OFF of the ISP Modem, RBR and RBS for 1 minute then back ON as well.
I did the power cycle and also tried AP mode .... neither worked.
Can you provide some more detials behind how to do this:
I found a setting named "Cascade Router"
It has these settings:
Cascaded Router
Subnet Mask:
I did a different test this morning. I unplugged the orbie from the frontier router and plugged in my old netgear nighthawk. With the night hawk I have NO bandwidth loss at the frontier router nd get consistent downloads of 30mb down and 4mb up. There has is something that has changed with the orbie with the firmware upgrade
