| Cascaded Router Enable: | On Off | |
| Cascaded Router Address: | ||
| Network Address: | ||
Subnet Mask:
Is this the same as IP Pass-THrough?
The router/wifi from Frontier is an Arris NVG443B ....
I will try to turn off the WIFI on that device .... but this issue just started happeing, We had no problems prior to the firmware update whcih I did yesterday.
Try a full power OFF of the ISP Modem, RBR and RBS for 1 minute then back ON as well.
I did the power cycle and also tried AP mode .... neither worked.
Can you provide some more detials behind how to do this:
configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi
I found a setting named "Cascade Router"
It has these settings:
Cascaded Router
Subnet Mask:
I did a different test this morning. I unplugged the orbie from the frontier router and plugged in my old netgear nighthawk. With the night hawk I have NO bandwidth loss at the frontier router nd get consistent downloads of 30mb down and 4mb up. There has is something that has changed with the orbie with the firmware upgrade
I did a side by side comparison of the orbi settings and the nighthawk settings. Everything was setup the same way except for UPnP! There was one entry in the portmap table on the orbi!!! I have no idea how that got in there. I deleted it and so far speeds are much better.
Turning the radios off on the frontier router and setting the orbie to AP mode made no difference.
