ARCFISH
Apr 30, 2020Aspirant
ORBI Lag Spikes while Gaming
Using an ORBI RBR40 Router + 2 Satellites The system works great for everyone but my son, who gets crushed playing online games due to lag spikes. The Orbi router is hooked up to an Arris Internet ...
ARCFISH
May 01, 2020Aspirant
Router Model = RBR40
Firmware = V2.3.5.32
Internet Modem = Arris TM1602
Lag happens when using ethernet or WiFi
Yes - there are other services in use during gaming. I think we tested with no other servies running, but I may try that again to see what happens.
robstall
Jun 11, 2020Aspirant
I've the exact same issue (right down to the frustrated son). Currently I'm running pinging the router from a wireless device. About every 30 seconds, the ping will spike from <5ms to >2000ms. This happens when either wired or wireless and I might not have issues for days at a time and then the issue will start in again. I can't pin down just what triggers it and it is really only noticable when gaming.
- FURRYe38Jun 11, 2020Guru - Experienced User
Is other devices online and doing streaming or surfing while gaming or ping testing is happening?Is gaming connected over wired or wireless?
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only.Has a factory reset and setup from scratch been performed since last FW update?
robstall wrote:I've the exact same issue (right down to the frustrated son). Currently I'm running pinging the router from a wireless device. About every 30 seconds, the ping will spike from <5ms to >2000ms. This happens when either wired or wireless and I might not have issues for days at a time and then the issue will start in again. I can't pin down just what triggers it and it is really only noticable when gaming.
