jbeem19
Sep 18, 2019Follower
Orbi Lag spikes
I just bought the Orbi with a single satellite a month ago. It worked perfectly until like a week ago and now when I play it's unplayable. 50 ping to 300 ping every 5 seconds or so. Very frustrating, please help. Thanks
Sort By
- ekhalilMaster
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (or traceroute 8.8.8.8 if you're using a Mac computer)
- If you see two private IP addresses listed in the first two hops then you have double NAT, and this can be the reason for the issue you’re reporting
- If you see only one private address and the second hop shows a public address, then you’re all good and we need then to troubleshoot further to find the cause of the issue,
What is the Mfr and model# of the ISP modem the NG router is connected too? If so,Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router
jbeem19 wrote:I just bought the Orbi with a single satellite a month ago. It worked perfectly until like a week ago and now when I play it's unplayable. 50 ping to 300 ping every 5 seconds or so. Very frustrating, please help. Thanks
