joshuap
Jul 03, 2021Aspirant
Orbi Lan connection issues
Hi! My orbi system (RBR50 with 2 RBS50) has been great, it provides strong and reliable wifi everywhere but recently a major bug has been troubling me. The system will randomly drop LAN communicat...
joshuap
Thanks for the response
Currently version V9.2.5.2.13SF-HW of voxel is loaded since i have found it to work best.
The satellites are ~10m and 15m away from the main base. They get good backhaul signal.
The house is around 221 meters^2 With brick walls that like to block wifi signal in some areas, and thats why we got orbi.
Both armour and circle are disabled
Hope you can help!
Jul 03, 2021Guru - Experienced User
You'll need to refer here for help and info since you have Voxels FW loaded:
https://www.snbforums.com/forums/netgear-ac-wireless.53/
Thank you.
- joshuapJul 03, 2021Aspirant
Will do. However, i do still think it should be discussed here as it happens on stock netgear firmware as well. This was the reason i tried installing voxel. When I installed voxel it helped a lot, but the issue is still there.
