OrbiMan
Mar 27, 2017Luminary
Orbi Lan speed
First my enviroment is roughly 5000 square feet Basement with 2 computer hard wired into a Netgear R7000 with DDWRT that been turn into a Wireless Bridge that have Ethernet run into an Old comput...
st_shaw
Mar 27, 2017Master
OrbiMan wrote:First my enviroment is roughly 5000 square feet
So I think going from NAS->>sat->>>wireless backhall->>>router >>>>wireless backhall cost me about 50-60% of my theoretical max speed of jacking into the NAS. So basically transfering file inside my net work max aout at ~350 mbps no where near the 866 mbps of AC
Sounds like you are getting good throughput all around.
Note that your measured throughput will never be more than about 50-60% of the reported WiFi connection rate (866 in your case), due to wireless overhead.
OrbiMan wrote:Right above the basement is my living room is an Orbi Sat with a NAS Hardwire into it with 2 ethernet cable that is bond together
I don't believe Orbi's switch supports bonding of Ethernet ports.
