pingles
Jan 03, 2017Aspirant
Orbi latency peaks every 10s
Hi, I've noticed that pinging the Orbi Router when connected to the satellite shows latency peaking every 10s, and lasts for about 3s. I'm hoping this isn't to be expected and something that ...
MarkC1024
Jan 03, 2017Luminary
Disconnected ethernet and using Wi-Fi there is a lag at about 26 seconds, but overall not as bad as what you are getting.
Pinging 192.168.1.1 with 32 bytes of data
Reply from 192.168.1.1: bytes=32 time=3ms TTL=64
Reply from 192.168.1.1: bytes=32 time=4ms TTL=64
Reply from 192.168.1.1: bytes=32 time=5ms TTL=64
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=32 time=7ms TTL=64
Reply from 192.168.1.1: bytes=32 time=6ms TTL=64
Reply from 192.168.1.1: bytes=32 time=31ms TTL=64
Reply from 192.168.1.1: bytes=32 time=46ms TTL=64
MarkC1024
Ran via Wi-Fi one more time and this time clean. I'd suspect you have something else going one:
Reply from 192.168.1.1: bytes=32 time=9ms TTL=64
Ping statistics for 192.168.1.1:
Packets: Sent = 60, Received = 60, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 3ms, Maximum = 9ms, Average = 4ms
- MarkC1024Jan 03, 2017Luminary
Agree with Mikey. A bit more info will help. You may have something on your nework that is broadcasting (ARP or other) every 10 seconds. Options are to trace the network to see who the offender is, or take components offline one at a time until you can isolate the source.
