YKkkk
Feb 17, 2021Aspirant
Orbi Latest Firmware not compatible with Yale Digital Lock!
Hi all, Recently i decided to upgrade my Orbi RBK50s firmware and it was the worst decision i ever made... only after installation that i realized Netgear actually removed the option for us to us...
CrimpOn
Feb 17, 2021Guru - Experienced User
YKkkk wrote:Recently i decided to upgrade my Orbi RBK50s firmware and it was the worst decision i ever made... only after installation that i realized Netgear actually removed the option for us to use Telnet to split the SSID for both 2.4Ghz and 5Ghz and now im stuck with my Yale Digital Lock that is installed at home and doesnt work as it is not compatiable with Mesh WIFI/ Network!
Anyone have any solutions on how am i able to split my SSID with the latest firmware for my Orbi RBK50s? Thanks!
The simple solution is to manually install the previous firmware and "re-split" the WiFi SSID's. There are some forum posts (100's of entries) about splitting SSID's on the newest firmware. It will take more time to wade through that in hopes of finding a solution than to install the previous firmware, but that is an option.
Yale appears to have more than one electronic lock. Which model is this one?
