davidcamm
Nov 18, 2020Follower
Orbi LBR20-100EUS NETGEAR LTE Router 4G LTE Advanced WiFi Router (LBR20)
Hi I have an Orbi Mesh WIFI system with 5 Satelites and was wondering two things. 1. If I buy the Orbi Router with LTE 4g, model LBR20 will my existing Orbi Satelites be compatible or do I ne...
Blanca_O
Nov 25, 2020NETGEAR Employee Retired
Hi davidcamm
Welcome to NETGEAR Community!
You can sync Orbi AC Satellites such as RBS50, RBS50Y, RBS40, RBS40V, RBW30 or RBS20 to the LBR20 router.
NETGEAR has several different SKUs of the LBR20 Orbi 4G LTE Tri-band WiFi Router products and each product has a specific set of bands that is supports based on the region that it is purchased in.
Please check KB link below for the list of supported bands:
What cellular bands are supported by LBR20?
Blanca
Community Team
