CharlesPorges
Nov 08, 2021Aspirant
Orbi LBR20 100NAS vs EUS model
I purchased an LBR20 100NAS to use in Europe but see that the input power brick specifies 110v 60Hz. I also noted that the EU cellular bands are different than the US ones. -Can I plug in the power ...
schumaku
Dec 13, 2021Guru - Experienced User
Bad plan.
-Can I plug in the power brick into 220v just using a plug adapter?
The power supply is the least problem...
Correct. Same applies to the WiFi channels available - a US FCC requirement, not allowing to change band plans.
