curiosity175
Aug 03, 2022Tutor
Orbi LBR20 and Starlink
Hello - has anyone tried connecting Starlink to Orbi LBR20 while also using a SIM card? We just received our Starlink gear and have ordered an Ethernet connector for the Starlink router. I'd really...
Aug 04, 2022Guru - Experienced User
the LBR20 can be setup with automatic failover. Meaning it can be set to use a wired connection and "failover" to the data connection if the wired connection goes down. so yes, you can connect another device to it. Page 21 in the manual goes over it.
https://www.netgear.com/support/product/lbr20
