tvarberg
Oct 31, 2023Aspirant
Orbi LBR20 can't disable 5GHz
Hi, I want my router to work only on 2.4GHz. In Advanced Wireless Settings 5GHz I have the following settings: Enable SSID Broadcast = Unchecked Enable WWM = unchecked CTS/RTS Threshold (1-2347...
tvarberg
Nov 01, 2023Aspirant
Thanks for your reply.
The purpose is only to turn it off temporary to link an ITO device.
Nov 01, 2023Guru - Experienced User
Try this. Turn OFF the RBS. Then the power output of the 5Ghz radio to 25%. Be sure that 20/40 MHz Coexistence enabled. Under Advanced Tab/Advanced Settings/Wireless Settings. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
