smithrd
Sep 23, 2020Star
ORBI LBR20 on AT&T
A bit confused. I called AT&T with the IMEI number and was told the LRB20 was not compatible - and therefore could not be activated. I called back a second time to see if the answer would change - ...
CactusHill
Sep 25, 2020Guide
I am having exactly the same problem and can't get a SIM card to actually work. AT&T appears completely flummoxed by third-party hardware.
I have tried a few different SIMs from AT&T, the closest I have gotten to having it work was a pre-paid data plan (DataConnect).
The LBR20 recognizes the carrier as AT&T LTE, the signal is good, but its status is always "disconnected." AT&T support is non-existent - I tried!
Anyone who had had success: what AT&T plan did you get? Any special settings on the router you used? Thank you.
