smithrd
Sep 23, 2020Star
ORBI LBR20 on AT&T
A bit confused. I called AT&T with the IMEI number and was told the LRB20 was not compatible - and therefore could not be activated. I called back a second time to see if the answer would change - ...
CactusHill
Sep 27, 2020Guide
Also, I have searched the forums (as mentioned) and can't seem to find a solution. If there is one out there, please link to it!
Thanks!
lilsadone
Oct 13, 2020Tutor
Totally agree with you regarding not finding the info on the forum. I think it's important to note, that we're referring to the NEW Orbi LBR20: 4G LTE Tri-band Router, and not one of the other Orbi products which are not 4G LTE routers, like this one is.
This router was only released in recent months, so those threads regarding ATT hotspots aren't actually applicable here.
- lilsadoneOct 13, 2020Tutor
lilsadone wrote:Totally agree with you regarding not finding the info on the forum. I think it's important to note, that we're referring to the NEW Orbi LBR20: 4G LTE Tri-band Router, and not one of the other Orbi products which are not 4G LTE routers, like this one is.
Actually, to correct myself: I found an ATT thread related, however, the Op was using a grandfathered ATT data-only plan that is no longer available.
