smithrd
Sep 23, 2020Star
ORBI LBR20 on AT&T
A bit confused. I called AT&T with the IMEI number and was told the LRB20 was not compatible - and therefore could not be activated. I called back a second time to see if the answer would change - ...
CactusHill
Oct 22, 2020Guide
Thanks for getting involved and helping!
What is the "right plan" for AT&T? I have tried asking them and no one seems to have an answer.
Thanks
vkdelta
Oct 22, 2020NETGEAR Employee Retired
are you facing trouble with a specific plan?
did the plan you choose have "hotspot" as a feature in it?
