PMC181
Jul 12, 2022Aspirant
Orbi LBR20 Signal Being Used and Manual Testing
Hi all, I have an Orbi LBR20 with cable internet and LTE Failover to Verizon setup for some time now. I can't seem to find answers to these questions in the manual or in this forum. 1. How can I...
- Jul 12, 2022
1) Advanced Tab > Internet Port window shows the current path.
2) Yes, just disconnect the ethernet cable, or power down the landline internet modem.
3) Yes, if you wired it correctly, everything will still work properly, but internet will be via cellular.
Note that it takes a couple minutes (about 3) to switch over to the cellular, and about a minute to switch back. I think this is to prevent wild switching on an intermittent connection.
burrington
Jul 12, 2022Star
- PMC181Jul 12, 2022Aspirant
Thanks for the help!
