PROAWEMIKE
Sep 19, 2020Follower
Orbi LBR20 with T-Mobile issues
Hello, I have an LBR20, I am trying to use it with a T-mobile sim and I can't seem to get it to connect to the internet. The sim works in another T-mobile hotspot device. I have tried APN:...
- Dec 02, 2020Unsupported device means that the plan provisioned to your “data SIM” isn’t approved by T-Mobile for use in your device. Typically you see this when people buy data plans (usually “unlimited”) through a reseller. What the reseller usually fails to mention is that their resold plan wasn’t meant to be used in a router device (because in reality it’s a phone or tablet plan).
I can understand the frustration but the device definitely isn’t a paperweight when setup with proper settings and/or plan on TMO. If you are at all tech savvy there are some good info here from another TMO user who is using the LBR20 without issues and has offered some support via email:
http://ltehacks.com/viewtopic.php?f=21&t=1876&sid=a358100f3a4526e612b295122419984b
Dageezer
Oct 20, 2020Initiate
I am using the Orbi LBR20 with T-Mobile. What I had to do was connect to the admin console advanced internet setup (http://orbilogin.com/adv_index.htm) and ensure the following:
Network mode: Automatic (4G or 3G)
PDP Type: PDP-IPv4v6
The setup 'wizard' had set it to just PDP-IPv4 which resulted in a connected status, but no actual Internet access.
lilsadone
Nov 09, 2020Tutor
Dageezer wrote:I am using the Orbi LBR20 with T-Mobile. What I had to do was connect to the admin console advanced internet setup (http://orbilogin.com/adv_index.htm) and ensure the following:
Dageezer any other tips? I'm also using a T-mobile sim, and although I can see signal strength on the admin console when I check status, I'm still not getting an internet connection.
I've already changed Network mode and PDP Type to what you've suggested (mine was also set to PDP-IPv4 by auto-setup, which didn't work).
