Kmcclean
Feb 19, 2021Aspirant
Orbi lbr20
Hi there, I have just set up the Orbi LBR20 with 2 satellites and it is working well. I notice a couple of antenna connection points on the router - are there any specific antennae which I would nee...
- Feb 19, 2021
Kmcclean wrote:
Hi there,
I notice a couple of antenna connection points on the router - are there any specific antennae which I would need to use and is it just a question of connecting up or is additional configuration in the router required for an external antenna to work successfully ?If you are happy with the system, external antennas would been to be "optional". People who have very weak LTE service, often need the antennas to get a good signal.
Be careful when searching for LTE antennas. Orbi LBR20 requires "SMA" antenna connectors. (there are adapters)
For example, Amazon's Netgear "Best Seller", comes with T-9 connectors https://www.amazon.com/Netgear-6000450-MIMO-Antenna-Connectors/dp/B00DN3J03O/ref=sr_1_10?dchild=1&keywords=orbi+lbr20+lte+antenna&qid=1613765287&sr=8-10 Other models (for half the price) include adapters in the box.
There are two connectors because the LBR20 uses "MIMO" to improve the signal quality. that calls for either two separate antennas or a "MIMO Antenna."
CrimpOn
Feb 19, 2021Guru - Experienced User
Kmcclean wrote:
Hi there,
- KmccleanMar 02, 2021Aspirant
Thank you very much CrimpOn. Very helpful response.
- FURRYe38Mar 02, 2021Guru - Experienced User
Be sure to visit the Orbi LTE forum as well:
https://community.netgear.com/t5/Orbi-LTE/bd-p/en-home-orbi-lte
Good Luck.
