k9kids's avatar
k9kids
Guide
Sep 29, 2016
Orbi light indicators
My Orbi base and satellite don't show any indications the system is working. Is there a feature that needs to be turned on?    Would prefer something I can look at to know all is well. Setup in AP ...
  • peteytesting's avatar
    Sep 29, 2016
    hi K9kids
    with the orbi system working you will see no lights , which is a good thing if the devices are in open areas , the only light you will see is the power light indicating the system is on , if there is an issue you will see different colored lights depending on the situation
    yes its a bit counter intuitive but seeing nothing is a good thing for the orbi once its started up and connected correctly
    pete
