k9kids
Sep 29, 2016Guide
Orbi light indicators
My Orbi base and satellite don't show any indications the system is working. Is there a feature that needs to be turned on? Would prefer something I can look at to know all is well. Setup in AP ...
- Sep 29, 2016
hi K9kids
with the orbi system working you will see no lights , which is a good thing if the devices are in open areas , the only light you will see is the power light indicating the system is on , if there is an issue you will see different colored lights depending on the situation
yes its a bit counter intuitive but seeing nothing is a good thing for the orbi once its started up and connected correctly
pete
peteytesting
Sep 29, 2016Hero
hi K9kids
pete
itGeeks
Oct 02, 2016Apprentice
Perhaps having the option to always show the status or maybe the option to set the times we want the lights to show would be a good thing to add for those wanting the visual. I am sure this could be added and have it user selectable.
1. Allways ON
2. Only on when there is a problem
3. Allows on during theses hours.
