Magnificent1
Jun 22, 2017Star
Orbi Light
Is there anyway to disable the orbi light? It goes from steady blue, to steady yellow. I'm fine with the connection speed that I'm geting since the router & satelite are so far apart. But the Satelite keeps insisting that I should know that they are so far apart. Any help? If I block the light with tape, would it eventually damage the device?
1 Reply
dont believe so , why have you got them so far apart
