badbet
Jul 09, 2019Aspirant
Orbi Limiting bandwidth wired and wireless
Hi all, I'm having a strange issue with my recently purchased RBR50 and I can't seem to run down what the culprit is. My ISP is Spectrum and I'm on their 400 down plan. I'm using the generic mod...
- Jul 14, 2019For the curious (@furrye38), replacing the rbr50 and cable seems to have done the trick. Bear in mind that I did test 4 or 5 cat5e/cat6 cables prior to replacing the unit.
badbet
Ok, I can find out exactly what model number it is. I remember looking last night and not seeing anything I would easily identify as a model designation. I believe it's reporting a 192 IP address. What should I expect to see if there is a router in the modem?
Unfortunately, it looks like remote management isn't working currently so I can't definitively say what firmware I'm on, but it is current as of last nights factory resets.
I did not actively enable any QoS, Armor appears to activate automatically. Could that be negotiating my link speed down to 100?
My home is probably around 1600 sq ft. The satellite and router are probably 20 feet apart, separated by one interior wall.
2.4 is set to auto, if I recall correctly 5 was set to 36.
No neighbors within a couple hundred feet on any side.
As I mentioned, bemforming/mimo/daisy-chaining/fast roaming were are enabled/disabled as a part of my troubleshooting last night. I did not make any changes to the WMM settings.
The part that's confusing to me is that the modem will give me a full 500 down when connected directly to my computer, but the second I plug it in, every link drops to 100 down.
Jul 09, 2019Guru - Experienced User
badbet wrote:Ok, I can find out exactly what model number it is. I remember looking last night and not seeing anything I would easily identify as a model designation. I believe it's reporting a 192 IP address. What should I expect to see if there is a router in the modem?
If the RBR is getting a 192.168 or maybe a 10.something IP address on the WAN port, if so, then there is a router at the modem. If the WAN reports a ##.##.###.### IP address, then there probably isn't a router at the modem.
If doing a factory reset and setup from scratch, Armor will ask you if you want it enabled or not. I would NOT enabled it. Others have mentioned this feature seems to cause some problems...
20 feet is too close. 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Keep Beamforming enabled. Daisy Chain is only needed if you have more then 1 satellite connected and placed in a linear line out from the router thus piggy backing of one another.
The part that's confusing to me is that the modem will give me a full 500 down when connected directly to my computer, but the second I plug it in, every link drops to 100 down. Need to find out the model and if this modem has a built in router or not.
