ppilot212
Mar 06, 2018Star
ORBI Limiting Internet speed to 100mbs
So recently Comcast Increaed the internet speed in our bundle to 150mbs, but I noticed after a couple weeks that I was still only getting 100mbs - Called Comcast and through their troubleshooting pr...
Mar 06, 2018Guru - Experienced User
What is the Mfr and model # of the ISP modem?
Is any QoS or Speed test enabled on the router?
Testing with different browsers like IE11, FF or Opera?
ppilot212wrote:So recently Comcast Increaed the internet speed in our bundle to 150mbs, but I noticed after a couple weeks that I was still only getting 100mbs
- Called Comcast and through their troubleshooting process, confirmed that I could get the 150mbs if I connected my PC directly to the Cable Modem
- Went through and checked all the cables to the modem, router and Gigabit switch, to verify everything was at least Cat 5e
- Ran speed test with the main PC (which connected directly to the router va ethernet) and my phone Pixel 2....both of the results were almost identicle.
- LAN speeds are just fine as file transfers typically max out around Gigabit levels.
At this point, I don't know what to do besides Factory Resetting the entire system again (which I have done since they increased my speed and had no effect)
Thoughts?
ppilot212
Mar 06, 2018Star
Motorola SB6141
Under the QoS tab the only thing that pops up is a speed test. Is that something that can be disabled? Just to add another layer to the wierdness that if I run the speedtest there I get the full speed.
Edge and Firefox were slightly faster, still not faster than 100mbs.
UPDATE: Reset my all my network hardware and I get the full speed now. Not sure what was going on but we are good to go. Thanks for the post!
- FURRYe38Mar 06, 2018Guru - Experienced User
Reset network HW as in? Did you reset the router?
ppilot212wrote:What is the Mfr and model # of the ISP modem?
Motorola SB6141
