tomsliwowski
Mar 22, 2018Apprentice
Orbi Local DNS?
So I have a number of systems that I've assigned static DHCP addresses and I was wondering if the Orbi has some local DNS server that I can configure to resolve them? I have a file server, a Plex...
Mar 22, 2018Guru - Experienced User
I don't think NG supports this feature. Usually NG has DNS Relay enabled always on most of there FWs and routers. NG doesn't support the disabling of this feature that I've seen. Also loop back may not be supported on Orbi.
Something you can ask NG support about and see. Let us know if you find out anything.
