tomsliwowski
Mar 22, 2018Apprentice
Orbi Local DNS?
So I have a number of systems that I've assigned static DHCP addresses and I was wondering if the Orbi has some local DNS server that I can configure to resolve them? I have a file server, a Plex...
Aug 28, 2018Guru - Experienced User
How do you edit the .conf file?
mvdp wrote:
See my comment on a similar request in the Idea-Exchange-For-Home list: orbi-add-dns-server/. This describes how to do add one line to the dnsmasq.conf file manually.
Ideally this one liner is in the conf file by default.
mvdp
Aug 29, 2018Aspirant
With the vi editor.
When you've never used vi read à tutorial first.
- FURRYe38Aug 29, 2018Guru - Experienced User
Where does one get this vi editor? Built in or external?
mvdp wrote:
With the vi editor.
- tomsliwowskiAug 29, 2018Apprentice
Vi is usually installed as one of the basic utilities in a *nix system. There are tons of tutorials out there on how to use it but honestly I suggest you play around in something like Ubuntu before messing with any files on you router.
As for how you get to the file, first you need to enable telnet on the router. Go to http://orbilogin.com/debug.htm and check off the "Enable Telnet" option. Then just telnet to your router IP and log in using your admin credentials (I think).
The hacky workaround mvdp linked to would work but since the config file is in /tmp I believe it won't survive a reboot of the router.
Yes for average or un-experienced users I would also not recommend doing this to the router.
So after you get into telnet, what is the next step, how do you edit the .conf file in VI? Is the file downloaded to the PC, edited then re-uploaded or edited live on the router thru VI?
Yes, hacy work around and not much information to go in is reason for asking questions. If some users are wanting to try this, then it would be nice to have exact steps. :smileywink:
