ajg617's avatar
ajg617
ORBI logging of ISP outage
Is there an option to log ISP outages in the ORBI?  We've been suffering through mulitple short (45 second or so) outages each day for weeks now.  I've talked with Comcast tech support which was futile.  Of note, when this occurs, I seem to lose ability to access other PCs on the LAN - i.e. a file transfer from one PC to another will stop and am unable to login to the Orbi as well.
For example, on 12/8 we lost all internet service a 5:04pm, 5:39pm, and 5:41pm - each lasted less than two minutes.  During those times, I could not login to Orbi or access a mapped drive on another PC.
TIA,
Ajg
  • And, yes, there should be local access even if there is no internet.
  • CrimpOn's avatar
    CrimpOn
    I believe the Orbi will log internet disconnections. Try disconnecting the WAN cable. Wait for the ring to turn magenta then plug it back in. See if this appears in the log.
    It is not clear to me that loss of internet would cause those symptoms.
    • ajg617's avatar
      ajg617
      Yes, the more I think about it, I should still have LAN access even if the ISP drops and I don't.  Can't seem to find a last boot time on the Orbi though.
      • CrimpOn's avatar
        CrimpOn
        Orbi logs "roll over" and events like that disappear. I have mine set to email the log to me every time it fills up. I can go 100 days without a reboot.
