aty1972
Jan 28, 2019Tutor
Orbi loosing Internet Connection on iPhone
Hi,
Since I've purchased my Orbi RBK50 Router and Satelite I'm facing this issue.
I constantly lose my internet connection on my iPhone and iPad. iMac and other devices connected to my WiFi shows...
ekhalil
Jan 28, 2019Master
aty1972 wrote:
...............The satelite is wired to the router (my only way of having a WifI signal on the 1st floor) ans is creating a signal upstairs. Backhaul status says good on routerlogin.net under attached devices.
Since you have the satellite wired to the router, please make sure that you have Daisy Chain disabled, as this can cause some strange issues.
This setting is found in the web GUI (orbilogin.com) under >> ADVANCED >> Advanced Setup >> Wireless Settings
aty1972
Jan 28, 2019Tutor
Thanks for the reply.
I've just disabled Daisy Chain. Will let you know if better.
