mtuhoop24
Oct 29, 2016Guide
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week. 3 time now it has lost all connection to the internet. I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
mtuhoop24
Nov 01, 2016Guide
OK I am taking my Orbi system back today and getting a different one. It keeps dropping the internet signal and Tech support has to call me back in 24 hours to get level 2 support. The first person on the phone last night said it sounds like a hardware issue with the Orbi.......so it is going back and I am going to try another. I hope that is it.
- bullgator91Nov 01, 2016Tutor
Thanks for keeping us up to date with your communications with tech support. I'm very curious if the new router will provide a fix. If so, I'm certain to return mine as well.
