mtuhoop24
Oct 30, 2016Guide
Orbi loosing Internet Connection
 Hello - I have had my Orbi installed for less than a week.  3 time now it has lost all connection to the internet.  I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
loribee928
Nov 05, 2016Aspirant
i bought an orbi yesterday .. and the setup went fine and download/upload rates were good. then it would drop the signal.. this happened about 5x in a couple hours. called tech support last night (fiber optic connection) and he said i had 2 ip addresses.. one was a new lease and one was 12 hours old. couldnt figure out why i had 2 but i figured one was on the old router and then when i installed the new router it didnt particularly like it.. i renewed the lease and for some reason it was registering both with my provider. Long story short i asked him to reset all my leases and problem solved. hasnt dropped since. now that i have been reading these i am guessing its because of the mac address issue i have been reading about or some problem like that.
loribee928
Nov 08, 2016Aspirant
update: even after the new leased address i did have one episode where my laptop said it was 'looking for connection' but otherwise good streaming on roku and good download/upload rates, excellent in fact. Tech support did come out to look at my connection and because previously a phone connection was also used in my house there was a box with a backup battery which can cause random errors when it is failing. He took out the battery since i am solely using cellular, will se if this fixes things. Coincidently this was the first ORBI this tech had ever seen, said i shouldnt have any issues, was impressed by the technology and seems committed to resolving any connection issues that might be related to the provider. we will see.
