mtuhoop24
Oct 29, 2016Guide
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week. 3 time now it has lost all connection to the internet. I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Schumi7
Nov 24, 2016Guide
Add me to the list of those with almost daily disconnection issues as well. I purchased the Orbi and Satellite system a few weeks ago. I immediately updated both to the current V1.3.0.26 firmware, so I have no basis of comparison to previous firmware versions.
When connected, the range, signal strength and speed of the Orbi system is brilliant in my house.
However, at least every few days, and some times more frequently, the system disconnects from the internet. There are no flashing lights on either the router or the satellite to indicate any problem. Its only discovered when devices (both Windows and iOS) cannot connect. The only way to fix is to power off/cycle on the Orbi router and wait for all to connect again. Several online interactions with Netgear support have failed to fix the issue.
All in all, daily disconnects and required resets are unnacceptable on a $400 router. I'm hoping for a firmware fix to be issued soon, or this unit will be returned.
JMU1998
Nov 24, 2016Luminary
Been facing this for weeks now eversince new fw, nightly reboots so frustrated so disappointed this product has so much potential but this fw is highly unstable right now it is a $400 decoration piece
- peteytestingNov 24, 2016Hero
so roll back to last fw till the new one is released , which wont be all that far away
- JMU1998Nov 24, 2016Luminary
It automatically upgrades to latest
- Schumi7Nov 24, 2016Guide
Agreed.
Backdating firmware is not an option. Tried that multiple times but the router automatically reverts to most current V1.3.0.26 version.
well just chill for a bit as the new fw cant be that far off :)
- PhoenixVNov 24, 2016Apprentice
I'm assuming that anyone having this issue has tried a hard reset to both the router and satellite, followed by setting up again from the beginning? I'm on the same version of the firmware and it is solid as a rock
- JMU1998Nov 25, 2016Luminary
Yes numerous times factory reset no luck issue starts in a day or two of factory reset... noticed a new fw 1.4.0.16 released today will try that to see if that helps and then do factory reset afterwards... anyone else try the 1.4.0.16 yet?
- mtuhoop24Nov 25, 2016Guide
Has this new firmware helped at all?
Too early to tell since it involved factory reset and reboot it is working OK for now issues star 1 or 2 days after reset and reboots usually
- getmetDec 25, 2016Initiate
This product is garbage. I am experiencing the same issue when i made a friend purchase this product after reading so much seeing this was the best of the mesh. Even though I knew mesh/wifi repeaters are always terrible + having so many bad experiences with Netgear wifi devices and constant dropping / power resetting. This product has been terrible on ALLLLLL firmwares. latest 1.4.0.18 is garbage too. drops throughout the day. causing tension with my friends family and me. terrible terrible product.
